Shouldnt my coil ground here..only 2 cyl work
Royalty
904
Apr 30, 2004
norfolk, Virginia
Car still firing on 2 cyls so my mechanic tries another coil and cas still nothing. took a test light and tested the leads to the coil to see if it was getting power.
Correct me if i'm wrong but those top wires should be powered and the bottom 2 shoud be grouded. Because if so all of mine are hot and that would leave me to belive that the ECU is the source of my problems.
THe caps were replaced by the previous owner and i think this is why he sold it.
also should i see this wire on the bottom of my ecu
I think you have idea backwards. Both coils share a common +12 and have indivdual wires back to the PTM so the the ECU can switch that side to ground causing the coil to charge. When the ECU swiitches off the PTM the collapsing field in the primary and fires the plugs.
The power wire is black with a white stripe and runs to pin 3 of the coil connector. The two wires from the PTM are yellow with stripes at at PTM side of the coil connector and go to pins 1 and 2. The manual doesn't describe the colors of the wires between the coil connector and the bottom of the coils.
The wire on the bottom of your ECU is a repair to the AC clutch relay circuit. Either it was damaged in the process od repairing something else or just went open.
I've seen that gold paint before, it's from one of the "professional" ECU rebuilders.
Not that it matters much but that's a FWD ECU. At least it's the right year.
Steve
Oh thats just fantastic (sarcasm & frustration)
I'll just get another one, #### this car :thumbdown
I assume your talking about the ECU, don't worry about it. The difference between the AWD and FWD within 91+ model years is a single resistor to tell the ECU what to be. It will work just fine (If your sparking problem isn't the ECU).
Which coil is firing and have you checked the Power Transistor Module?
Steve
Steve
i'm going to try a new transtor and ecu today so i'll let u know how it goes
Definately sounds like a transistor pack problem. If it is 1&4 or 2&3 out in those two combinations, i can say with 99% confidence that it is your transistor pack.
Scott
Scott
transistor pack, thats the thing tucked on the side of the intake mani beside the cam geears..rihgt?
Yeap. It is a 6 or 7 pin module (depending on the year) that is directly below where the wiring harness connects to your coil pack.
Good luck
Scott
Royalty said:
could i use an N/T 2.0 power transitor
i got a few from a junkyard off the n/t 2.0 models and they still worked on mine(90 tsi) its exactly the same part if the years are correct(if u get one that has the same number of pins on the transistor as yours it wont matter if it was from an n/t 2.0 or the turbo model)
So since i have a 91 i have to use a transistor off of a 91
and 92 to 92 and so on and so forth?
Is this correct
  • For sale 4G63 Competition Clutch, Clutch Fork
    Competition Clutch, Clutch Fork $75 + shipping and PayPal feesYou must be registered to see...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
