my rear wheels lock up when i turn and i hear grinding noises when i turn
xxtwistedpnoyxx
Oct 24, 2002
whenever i turn my rear whells lock up and i hear something grinding in the rear end. What could the problem be? can someone help.
Well of course the worst scenario is that your rear differential is going out. $$$$$. But you could get lucky and it could be a cv boot that has been open for a long time, and has stored up enough dirt, water, and grime to lock up your axle. If this is the case you are maybe looking at a max of $80. Well I hope that i was some help.:)
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
