doksoori
- Jan 6, 2005
Sunnyvale,
California
I have a 95 Eclipse on which I replaced the valve cover gasket. After replacing the gasket, I drove it to the local safeway. After shopping, the care wouldnt start. It would turn over.... but the engine hestitated quite a bit for a few seconds and then would die. I could never get it past that.
I brought it to a local shop. They enticed me to replace my cat and muffler (which I did, since I needed them to be fixed anyways). Then they called me back to tell me that the camshaft sensor and the crankshaft sensor needed to be replaced.
Question: Does it make sense that these two sensors need to be replaced at 50K miles? Could I have mistakenly messed with these sensors when I took the valve cover off? (I have no idea where these sensors are). Thanks a ton!
-hjk
-hjk
