Low RPM when idling even when adjusted the BISS screw
TSiRocker
56
Dec 6, 2004
Texas, Central America
Hi,
I have a very strange behaviour on my engine. It always idle at 700rpm now. I have adjusted the BISS screw all the way up and still it idles at 700rpm. What could be the problem?
thanks all, but my battery is relocated to the rear trunk, so can I just hook it to anywhere on the car body chassis as a ground point?
Also, what happen if I ONLY ground the Timing Adjustment connector?
