biss screw
cookmaster30
58
Nov 20, 2004
bainbridge, Georgia
hey guys,
what all do i have to do to change the biss screw in a 1g. its my last boost leak to fix :)
Is there a way to get the BISS out completely? I've tried magnetic screwdrivers but then heard the screw wasn't metal :rolleyes: I want to change the o-ring on it, but it only backs out so far.. I've tried about everything to get it out.. Any suggestions?
hehe,tri this.loosen it all the way then have your buddie stand over it.then all you have to do is start it and rev it.the damn thing will come screeming out of there and hit him in the face.well thats what happened to me anyway
girlieracr4g63 said:
After you fix it, and have it set where you want it. Throw some RTV over it. That way it has a harder time backing out on you...Also, dont worry you can get it back out if you have to.
Spray in a bit of WD-40, then RTV it, and it'll come out like somebody meant it should.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
