shawntalon
- Aug 9, 2004
Clinton,
Iowa
I have been having a problem with my 91 Talon (Tsi AWD).Which has only 5000mi on a remanufactured engine, in which I run 93 octane only. It Idles awful high(about 1500-2000 rpms) until it warms up, and then It idles up and down constantly, unless the head lights are on and the heater blower motor is on high and I push the a/c switch in one notch so the secondary cooling fan comes on.Then it doesn't surge but still idles about 12-1500 rpms. On top of that, It has been getting fuel cut (I think) for about the past week. The mpi relay keeps resetting and cutting the fuel, sometimes it will run fine( other than the rough idle) and sometimes it won't stay running. Just to get back and forth to work, I jumped a wire from a constant 12V to the fuel pump wire that comes out of the relay and goes directly to the fuel pump. Then it runs okay (outside of the idle surge)If I counted the needle sweeps correctly on my multimeter, while checking the diagnostic codes, it points toward the barometric sensor, and the air temp sensor. When I tested the componets the way the haynes manual says to, it all checks out okay. Here's the weird part, if you unhook the MAS without the jumper wire on the fuel pump, it will stay running, but awful roughly, but you can still hear a clicking from under the dash. Any Ideas? Does it sound like a MAS problem, or time to get another ECU?Know where to get an ECU that is in good shape? I took mine apart and it does look like the capacitors could be leaking a bit, not sure though.If so can the board be repaired if it doesn't have too much damage? I need to find a solution before I fry something by bypassing the relay. I have tried swapping the mpi relay, the Idle speed control motor, tested the o2 sensor, checked for air/turbo leaks,and several other tests.
