Balazs
- Nov 29, 2003
Budapest,
Europe
Hi,
I had my front brakes upgraded with Diamante calippers from the junkyard. They were rebuilt before installation. Also one of the rear calippers needed rebuilding. I bought new discs and pads, both in the front and in the rear, and also the brake fluid was replaced, of course.
So basically I have four brand new brakes.
I think the brakes were bleeded properly (first in the rear, then in the front, then the rear again). I took the car for a test drive but I could push the pedal almost completely to the floor (I tried it with and without the ABS). Then all brakes were bleeded again, and some improvement was noticeable (there was a very little air in the rear). Unfortunately I still have to push the pedal much further, then with the old brake.
Is there still air in the system, or it is usual when installing big brakes? Maybe the pedal must be pushed more to move the extra oil that is needed for the +2 pistons?
