2gdsm_nc
- 136
- 1
- Oct 24, 2002
Elkin,
North Carolina
car is a 95 gsx 90k on it
about two weeks ago I had a problem with a bad vibration from the driveshaft on heavy acceleration. Took it to a shop and they removed the shaft. 2 of the u-joints were locked.
I had them replaced=not cheap since you got to go to mitsu to get them. well anyways.
I got the car back first thing i noticed was a clicking between 18-25 or so mph going straight, turning it doesnt matter. 2nd thing i noticed was a popping noise from drivers side rear lower speeds. I would say when it bumps but hell it does it on smooth roads too. cant notice it between 50-80.
now for the part that really bothers me. a buzzing/metal rubbing hummm. it is loud comming from the rear also but it only starts up between 80-85 mph then buzz all the way up to 140.<not smart but i wanted to see if it would stop at higher speeds.
the driveshaft carriers felt good to me no wear and still had play in them.<not stiff. the only thing the shop said is that the little rubber pieces with the metal inserts that go from the body to carrier were worn out and that may be the prob. I highly doubt that though.
Im about half tempted to get the drivshaft shop driveshaft and chuck this one. but could it be my rearend? the poping i beleive could just be a strut. all axles are tight no play. so that cancels that.
any idea's... tired of dumping cash into it, oh wait i bought a dsm my fault, :laugh:
fix it!
