AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
Ok I have the classic symptoms of a bad alternator.Batteries die within a few minutes,lights in dash dim and car starts bucking and barely running and then dies out.
I tested and have like 10 volts coming at battery when car is running.
Since alternators are big money and did lots of reading about it and found out sometimes its just a blown alt fuse.Well here is the deal.I looked at the 100amp alt fuse and it looks ok,not really sure how you pull that one out .The other ones just pull out but that one seems to have a trick to it.It looks ok but want to take it out and try another one in there just in case.
Also I did find a blown 30amp fuse a few fuses away,its marked alt sens and something alt and it for sure is gone.Just borrowed one off something marked belts I think my car has the manual belts not auto assume that is what the belt fuse if for.So can the 30amp fuse I found blown marked alt also cause the alt to not charge up the battery??
I am really hoping it can.
