l3LacK Tsi
- 73
- Aug 30, 2004
virginia beach,
Virginia
ok ive searched and searched tried a few things but i still have no idea whats wrong with my car. 1991 eagle talon tsi fwd. this is what happens. car starts and runs fine for about 20-30 mins then idle drops and is unstable usually from 800 rpms to about 300 give or take a few then it will just die out this is at idle the whole time i put the key in start it and sit there. ive tried adjusting the throttle didnt work. got a ecu for dsm trader . did plugs and wires (ngks from mitsubishi) checked the coil pack and spark from each wire was fine compression is 168 the whole was across and untill i check timing this weekend im not sure about that. i did a complete check of all vaccum lines checked all my IC piping didnt find any leaks. any ideas??? oh ya the alt. is putting out 14.6 volts. like i said any ideas will help thanks.
