90 GSX
- 322
- 2
- Jun 24, 2004
Fremont,
California
I need help figuring out exactly what this problem is. Engine compression is okay but could be better (ranging from 140-150). It has many new parts, knock sensor, isc, crank pulley, all belts to name a few. Basically when I got this car it wasn't running too well but it was in good condition, I fixed a whole buttload of things. I set the base timing back to 5*, I swapped to a 91 eprom ecu with new caps.
Okay anyway, that was just so you have an idea of the car. Now for how it actually runs and the problems i needed help with. The car is bone stock except for the K&N air filter, joe p mbc set to 10psi, and the ecu and some other little stuff that has no effect on the motor. It will get anywhere from 5-15 (maybe more I can't remember) knocks on my datalogger under boost usually past 5000 rpm or so. The amount of knock and the point at which it comes on varies, but basically when i get on it there is some sort of knock going on. Would a bad injector cause any of those problems? What about a boost leak. Like I said in the subject, all my fuel trims are at 140% like the comp. is trying to compensate for something. At full boost my timing will drop down to around 18* give or take one or two degrees but I have seen it go as low as 12 or 13 once that knock starts kicking in and the power just drops off the face of the earth.
I also have a problem with the car dying at idle with the a/c on or when it's still really cold and I come to a fast stop and I'm pretty sure it's all related. Overall it runs okay that's why I have lived with it but I need to get it running really good so I can start modding and having real fun, I run just about even with my buddy's 1.8 acura ls so I know it has a lot more power once I solve these fuel issues, I just don't want to get on it too much like this...
Here's a really important tidbit. I don't know what kind of vacumn dsm's are supposed to make, but mine makes anywhere from 13-16 in hg. So can anybody help me out or give me advice on things I should do to solve these problems I'm having. Is it a boost leak? I have made a boost leak tester per vfaq but I didn't have a boost gauge. I still connected i t up and used my judgement so I didn't go too far with the air and I couldn't get it to pressurize. The motor was at #1 tdc (piston on the far left standing infront of the car)... anyway, did I do it correctly by attaching the tester to the turbo inlet??? Or do I need to attach it to the LICP??? Is there anything I need to block off to make it work? I have a boost gauge now, whats an appropriate pressure to test with.
Englighten me.
Englighten me.
