skybound74
- 33
- Sep 21, 2004
levittown,
Pennsylvania
Ok i recently aquired my 91 talon TSi from a friend of mine. It came to me in a condition that i thought was a blown head gasket. smoke from the tail pipe and coolant all over the back side of the motor. Me and a friend of mine removed the the head after sixe hours of labor one 2" extension and a roll of masking tape later. when we pulled the head gasket away from the block it apear to be a gauge out of it as if maybe it had been replaced before and the head had been droped on the gasket and damaged before they put it all back together. anyway the buddy of my i bought the car off of took the head gasket to a mechanic and said that although it was damaged it shouldn't have caused the smoking and coolant leak. the valves are pretty dirty and aren't sitting quite right due to carbon build up i know this cause in the dark i can see through the valve hole when i put light on the other side. could this be the reason for the smoking and if so where is the coolant posibly coming from.
