tsi95dsm
- Jul 9, 2004
Ontario,
California
Alright guys i need help! It all started when my oil filter got loose and the car shut-off, ofcourse lost most or all the oil since i had just gotten off the freeway well I notice the gauge and didnt turn on the car until I poured more oil, it turns out the O-ring behind the oil-coolant broke and the rod that holds the oil filter got loose. Well I got a new O-ring and tighten the rod and the Oil filter. Drain the leftover oil and added new oil. It stayed on for a little bit and turned off, turned it on again and then I let it iddle for a good 20 mins. Luckily I didnt messed up the valves. A weird noise came up and then I drove around and it slowly went away but then I noticed white smoke out of the exhaust?? Well it went away and then I drove from LA to San Diego ,bad idea, I got stuck in San Diego the turbo shaft broke and it let oil into the intake causing lots and lots of white smoke! Now I got a new turbo and Im not sure why the turbo blew and what are the steps I should take to install the new one, what must I clean or replace??? I need lots of help! Thanks!
Could the lack of oil cause seals to break in the turbo??
