v8killerr1
- 182
- 3
- Mar 6, 2004
Bowling Green,
Kentucky
ok here is the story. The car is a 97 eclipse gst with following mods:
b16g
afc
550cc inj
exhaust
datalogger,egt
Tonight I when to the track to run it for the first time since i put the injectors. In I had tuned the lo thrl on the car, but not yet on the hi. I put 2 gallons of 110 octane mixed with a quarter tank of 93 octane with boost @13. Started my first run and after i shifted into second gear my car just died. I thought i blew a hose or something, but the car does not idle (have to hold gas to keep from dying). The car is getting way too much gas or something, my spark plugs keep on getting carbon on them. My first thoughts was that the gas had something to do with it so i put 5 gallons of 87 octane to bring the octane down and changed my plugs. Started it up ran better for about a minute then started to smoke black pretty bad and you the gas smell is very strong. I was getting the following check engine codes:
Engine temperature circuit
intake Air temp circuit
manifold absolute pressure/barometric circuit
the air temp won't even show up on the datalogger and the coolant temp is -40f.
I've tried everything that i know of and i need help before i become a nervous wreck. The car ran fine before i went out to the track. I didn't blow anything up did I?
b16g
afc
550cc inj
exhaust
datalogger,egt
