98spydert
- 1,916
- 8
- Jan 16, 2004
Phoenix,
Arizona
Well it's almost midnight and I'm done for today. I just finished my little project; rebuilt head, head gasket, ARP studs, blah blah blah lots of gaskets and other replacement maintnence parts. I started it up after the timing belt was on and tensioned and everything was fine. I put the covers back on and put the pulleys and accessory belts on and started it up again. The loudest squeel I've ever heard came from the car. I turned it off, looked over everything. Started it again and the same thing. Then I turned it off after about 10 seconds and the alternator belt was HOT to the touch. I'm guessing the pulley is just spinning inside the belt but I'm not sure, I just came inside for the night. I thought I'd throw this up here so if it's something common, I'll know about it when I go out tomorrow afternoon to finish her up. So if you've got any ideas or common problems I should check for, I'd appreciate it.
