dfgu
- Aug 3, 2004
ny,
New York
Hi.. I know this question has been hacked so many times.. I've done a lot of research and found no right remedies for my problem yet.
I have a 91 tsi awd... It blows out white smoke when at idle and a whole bunch when you open the throttle...
I put a glass next to the exhaust where the smoke is comming out, and it definately is not oil... It's water and a lot of it...
THe car is not heating up, and there is no radiator fluid missing either...
I know white smoke equals water being consumed somewhere, but the awkward thing is, the resevoir tank is at half where it should be, and the radiator fluid is full where it should be...
I know there are 2 things that could be wrong when white smoke appears... Either the Head Gasket or the Water Pump.. If it was either one, wouldn't radiator fluid be lower? It's still at the top and I never added any in..
I just purchased the car about a week ago with this problem. I got a good price so I didn't mind. I did notice that I was almost 2 quarts low. But if oil is burning, it should be a blueish smoke and if I put a piece of glass where the exhaust smoke is comming out, shouldn't I get oil?
I'm hoping the previous owner just didn't fill it up all the way or something so that's why i'm missing oil. I know the previous owner didn't drive the car for at least 2 months before he sold it to me..
I know, I should do a compression test/leakdown test. But I would like to see if there's anything I can do to narrow it down myself first. Like I said, if it was HG or Water Pump, I should not be full on radiator fluid right? And the engine should be getting hotter too..
I checked the pcv valve and its fine.. Not sure if that's relevant..
Any suggestions or help would be greatly appreciated...
Thanks..
Thanks..
