gump1976
- Aug 8, 2003
Seaside Heights,
New Jersey
Hello everyone. Well I've done some searching around and everyone is quick to say 'ISC' when the problem of RPM's dropping when the A/C is turned on. For most people maybe that is the problem, but I dont think it is my ISC in my case, which leads me here. I have changed mine out with one I bought from Crebotech and it seems to be working fine. On my TMO readout, at idle, I can watch the "Idle Steps" readout go from single digits, all the way up to 130 after I turn the A/C on and still just drops about 200 rpms. I turn off the A/C and the Idle Steps number returns to single digits. I have taken the tb off and cleaned it well, changed the tb and tb elbow gaskets.
Is there anything else in TMO i can look at that might help me determine what the problem may be? My TPS seems to be fine as it goes from .51v at idle to 5.00v at full throttle.
When I pressure check my intake path, I can hear a leak from what sounds like the throttle body shaft seals, can that leak cause this problem?
This is really bugging me, I can't even try to run the A/C and have the headlights on at the same time because it will stall out when I stop. Is my throttle body just shot? Please help, and suggestions.
