No Spark!!!!!
Itzallstock
244
May 19, 2004
Millbrook, Illinois
My car is in a mechanics shop and is getting worked on. The car ran bad before it got there. It was a combo of things. I new fuel pump was installed and they pulled the car out of thye garage and back in. When they went to start it back up they got no spark. The engine turns over fine. Theres jsut no spark. They replaced the coil pack and that did not work. I guess there is a resistotr beofre the pack....sometimes called the "power pack"????
Any ideas??? Crankshaft pos. sensor?????? ecu????
-NO SPARK AT ALL
Ben
It will suck if i have to replace all that. Can that really casue the car to have NO spark????
Thanks
Ben
my car had the same prob, i checked everything even swapped ecu's, turned out to be the CAS....... thats where i would start, try to borrow one from a friends car and check :thumb:
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale EVO 9 Blow Off Valve
    EVO 9 blow off valve $60.00 In good condition, came off 1995 Eagle Talon Tsi. Comes with factory...
    • jmt2028
