engr2er
- Aug 15, 2004
warner robins,
Georgia
I have a 91 eagle talon non-turbo the problem i'm having is 5 secs after start up it will shut off... I've grounded out pin 7 of my mpi relay and the continues to run and the CEL comes on with alot of smoke out the tail pipe.. I'm in the process of changing my caps but is there something that tells the ecu not to supply that ground after start?? what will forward bias that transister to supply a grd. Is there a schematic on the internals of the ecu??
