crash27578
- 277
- May 5, 2003
Livingston,
Tennessee
I'm having trouble with the car starting. If the car hase set for a while it will start up fine but let it get warm and turn it off for about 5 minutes and it won't start back. The coil for the #2&3 cylinders is not firing when it won't start but #1&4 is. I replaced the coil and it didn't fix it. I though it was the power transistor so I replaced it. Nothing. :thumbdown I've narrowed it down to the ECU or the wiring because I can unhook the battery and reset the computer and it works again until I turn it off. I've heard to check the ECU, remove it take the cover off and check it for cracks and burnt spots and see if there is a fish smell. Is there anyway to check it with a multimeter or something like that. If it is the ECU What would be a good way to fix it? I've though about a AEM EMS or something like it but I don't know if you have to have your stock ECU or if it replaces it? I would like to know. What are my options for a replacement? Any help is appreciated.
