95EclipseGST
- 406
- 1
- Mar 1, 2002
Kansas City,
Missouri
From what i was reading on here,if you arent getting boost you should disconnect the wastegate and see if it gives you at least a few pounds "9lbs"? I completely disconnected the wastegate and the flapper is very smooth.The wastegate rod i can pull out from the wastegate actuator on with vice grips with some pressure applied.Seems to have good tension and everything.But going driving with the wastegate disconnected where the rod meets the flapper should have given me boost right? My next door neighbor " american car enthusiast" says i need my manual boost controller running from the wastegate teed off with the top of the turbo "j-pipe with the nipple" But i have a dejontool Lower ic pipe and that doesnt have a nipple on it,however the diagrams i was looking at say to just go from wastegate tee'd off to the "BOV to Intake line" Thus NOT using that nipple thats normally on the top pipe of a 16g. I ran with the MBC all the way open and all the way closed and got 2lbs of boost at one point.So i thought wastegate problem and disconnected that,No boost at all.So where do i go from here? I dont have any leaks "maybe i need to check again" but should i have needed to wire that flapper open and go drive it? I dont know what to do from here.Any thoughts on this?
