95GSXBLUR
- 405
- Sep 28, 2002
Indanapolis,
Indiana
I put my 14B on the other night and I drove around and tested everything out and I get good boost and it holds pressure... No leaks or anything.. so that's fine. The problem is, as soon as I turned the car on with the new turbo, I noticed that my A/F Gauge isn't working. not only that, a few hours later the Check engine light came on and the diag was "bank one rich" and the engine was taking a little while longer to heat up (two). Well i got the light reset because i figured the ECU had to map new curves for the Fuel but it came back on today. i gotta go get it checked out tomorrow. any ideas? Bad O2 sensor maybe? any help would be appreciated.. especially anyone who ran into something similar when swapping a turbo thanks!
