jumpman
- 83
- Jan 4, 2004
Winston-Salem,
North Carolina
Hi people.
It's been a while since I've visited but I've got a wierd problem with my car that I can't quite diagnose. Recently I've been running super rich and had a massive boost leak coming from my BOV (the 1G BOV adaptor kept slipping out of the stock 2G IC pipe). I fixed the latter problem with new IC piping from Dejon Tools but the fuel problem is still there. As a matter of fact the last code I threw was a P0170 which is a fuel trim problem and a couple of days ago I threw a P0300 code which is random misfire. So I cleared the error codes with my pocket logger and did a couple of test runs with the logger on and the results totally confused me.
At idle I have these numbers
Calculated Load of 17%
Short Term Fuel trim of 17%
Long Term Fuel Trim of 12%
Throttle Position of 1%
O2 Bank 1 Stuck at 0.00 Volts
O2 Bank 2 Stuck at 0.74 Volts
At WOT I have these numbers
Calculated Load of 95%
Short Term Fuel Trim = 0~6% (0 on flat ground 6 on slight incline)
Long Term Fuel Trim = 8%
Throttle Posisiton of 75%
O2 Bank 1 at 0.16 Volts (Sometimes doesn't even move)
O2 Bank 2 at 0.94 Volts
To say the least I think there is something very wrong with my fuel handling system but it may be something else that I can't think of.
Any help would be appreciated.
CMF
CMF
