little help?
awd4me
May 17, 2004
pekin, Illinois
as most know, i put a tranny in my car....when we tried to drive it it wouldn't go into 1st or reverse....we took the slave cylinder of the car and bled it and put it back on and now it goes into reverse, but still not 1st....we had to put a different battery in it because it wouldnt start....everything seemed fine, drove it around the block, but once it got to about 4500 it seemed like it was hitting fuel cut....we got it back to his house and it started actin really strange....it would idle up to about 1500 and then the CEL would come on, it would backfire and then drop to about 600rpm....it did it a few times and i shut it off....tried to start it back up and it wouldnt...another dead battery....any suggestions?
Have a pocket logger to see what the CEL was?
IDK did you hook everything back up right and at all? Thats a wierd problem, sorry I don't have more dude. If the battery dies, check your grounds and connections for the battery. Also the idle is going to be the idle control sensor, or the Throttle position sensor.
