ManHaTTan
- May 15, 2004
Vancouver,
Why wont it run properly?
Stuff I have done in the past week.
Replaced Waterpump
Replaced Valve Cover
Oil Change
Rad Flush
Car idles like crap ie. vibrates (whole car)
Once it hits 1200rpm+ vibration stops
Stalls when it goes up past 4500rpm (once you remove foot from gas pedal)
The coolant in overflow res was bubbling
Problem, I think is timing is off but the timing belt was put on exactly the same way it came off. All marks were lined up.
Replaced Waterpump
Oil Change
Rad Flush
