Alternator connections help
BoosterBump
May 14, 2004
Vancouver, Washington
Is something supposed to be connected here?
Was just curious because my alternator isn't charging the battery,
so that explains why my alternator isn't charging.
How big is the cable that goes there? I need to look for it. What type of plug also.
thanks again
It should be attached to the same bundle that the other connector comes from. The wire should be at least as thick as a pencil and terminated in a ring connector. You'll need the nut that fastens the wire on too. I don't see it in your picture.
What car is that alternator from?
BTW, that's usually called the B+ terminal
Steve
The picture was just to show what part I was talking about. My car just died on me the other day and after taking a look at it (the alternator) I noticed that there's nothing going to that stub.
Hmm... I always thought that wire was a ground; I'm stoopid.
It's not that big of a wire, but it's around there somewhere, or should be anyway.
it's a small wire right? I found one there that wasn't connected but I can't seem to slide it back onto that post
I found a wire that's bundled up with the 2 wires that plug into the alternator. It has a female end bullet connector on the end of it. Should I just try to put this wire there?
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
