Low Oil Pressure (Long Post) Big Problem
blue92laser
267
May 13, 2004
Laurel Springs, New Jersey
Hey, Ive been having low oil pressure for a bit of a time now. Let me give u background on when it happened and then Ill go from there.
I was at the track one day and on my 3rd run my flywheel had came loose. At this time I checked everything. Oil pressure, vacuum, and temp. Nothing seemed to be different from before so I took the car home gently at around 25mph with the hazards on pissing off every impatient driver on the way home, but thats a whole different story.
When i ripped the tranny out, I also took notice one of my camgears were missing one of the 5 spokes that go to the cam gear teeth. So, i decide to do a timing belt change on the car. I get down low and discover there is no balance shaft belt left on my car. In fact the teeth were everywhere and the belt looked like a alternator belt.
I go ahed and set the timing up, redo the balance shaft belt, put a new cam gear on the intake side, fix the flywheel and 16 hours of horrifying work later...the car starts.
It started up ands tumbled to a stahl, did the same thing a few times. I realized teh BOV return line was off so i routed tht back in. I started the car and it had bad oil pressure, it didnt sit wear i normally sat at idle and bad vacuum (-10Hg). I thought my internals were done.
Next day, I decided to rip the oil pan off and check the bottom end, to my knowledge eveyrthing was tight. I proceeded onto the timing thinking i might be pulling bad vacuum from a cam being off a tooth. Timign is perfect on every mark.
I put the car on the computer and find out the MAS is practically dead and the o2 is running in a constant closed loop (or open loop) which ever one is bad, i forget :).
I replaced the MAS and the vacuum settled out at -20Hg and my idle returned to normal.
My Oil pressure is still low though.
Which brings me to the main point of this thread, can anyone help me diagnose a low oil pressure problem.
If it was my main or rods, i would be making knock noises and if it was my balance shaft bearings going bad, they would make pretty bad noises too.
I here absolutely nothing from the bottom end.
Also, when i drive the oil pressure raises up but doesnt really return to normal driving oil pressure and when i get in it, it goes up even more, but never to where it was before.
:rolleyes: Bad Balance Shaft Bearings - which is why you threw the Belt - no oil pressure - ETC - In between racing the piss out of the thing & tearing it down over & over you need to do what you should have done to START with & get rid of the damn things - Put some Rod Bearings & an Oil Pump in it while you are down there! :dsm:
Blue92Laser: "I get down low and discover there is no balance shaft belt left on my car. In fact the teeth were everywhere and the belt looked like a alternator belt"
DAMN, why couldnt I have just put 2 and 2 together and got 4.
Anyways, the belt have on there now is fine in fact its still has all the teeth and, it spins freely. Wouldnt balance shaft bearings make noise along with rod bearings?
It could be that though, but the belt that was on there was over 12 years old. Why was it?...when i got the car it had only 29,998 miles last year.
