bensgst
- Jan 19, 2004
Boulder Creek,
California
OK, just got my re-manufactured ECU put in the other day and today was the first time I had a chance to run the TMO with it. Warmed the car up for about ten minutes, then took it for a quick drive around the block. Got home and checked the logger and it shows 43 counts of knock. Even worse than before I had the ECU work done. Havn't had a chance to look inside the head, but last compression check was good across the board. Have an exhaust leak at the O2 housing, but other than that everything seems fine. What might be causeing the knock and what else should I look at. Thanks.
Will try to upload a TMO image if I can.
