92Talon251
- 220
- Sep 26, 2003
Fayetteville,
North Carolina
I got a 92 Talon Tsi AWD and I am going nuts trying to figure out whats wrong with my car. Let me give you some backround on what I have got done. I have a 2.5 with high flow cat from the flex pipe will be getting down pipe once I get my flex piece in. I have put new spark plug wires/ spark plugs in both NGK new stock fuel fillter and put a 3" intake from Mach V from air box to the stock 14b turbo.
Problem
The problem is this when my engine starts to warm up (when the temp guage goes past the first line) an reachs about normal. When I come to a stop the car will have a HORRABLE take off I mean the RPMS are slowly climbing and the turbo is at full spool my boost guage is reading about 8 psi (which is where I have it set on my controller) gas petal is to the floor but the car isnt going any where. One thing I thought it could be was the turbo my turbo has 138,000 miles on it (it has never been rebuilt) I am tempted to put my Big 16g on to see if it will make a differance but am holding back to see if it could be somthing else i have just came back from the dealer they said 02 sensor was weak I replaced that and still getting the same problems. Did some searching found out about PK (Phantom Knock) not sure if that is it but still unsure. I am about 80% sure there isnt a leak some where but I could be wrong been hearing leaking air from around my passenger side tire but just think it is because i have cut holes in the plasic vent to let air flow threw the Inner cooler better. Any help would be much Very helpfull
Thank you
Problem
Thank you
