jmartinez1228
- 359
- 2
- Feb 20, 2004
Rocky HIll,
Connecticut
Ok so yesterday i was letting the car warm up and i noticed a weird grinding noise at idle. At first i thought it might have been an old flex pipe gone bad but when i layed under the car it sounded like it was coming from the tranny. THe car shifts fine and everything with no problems. BUt the grinding noise i heard was at idle. now it would go away and come back.....any input?
Second when i waslooking under the car i noticed that there was some fluid leaking from what looked like to be the transfer case. If im correct the transfer case is what the driveshaft is connected to right? Well i moved the car to see what kind of fluid it was and the fluid was greenish im not sure what transfer case fluid looks like but could it be fluid from there or can it be coolant? Could there be somewere that im leaking fluid from? THanks
