Turbo Question
In-Serenity
Jan 17, 2004
Hazlet, New Jersey
Hey,
I have a question. I just blew my T28 a few weeks ago and recently swapped the stock T25 back on. Ever since the stock turbo has been on, it doesnt feel like a smooth transistion when it spools up. It feels as if the turbo is on or off, there is no in between. I was wondering if it could be because I have not put the gasket between the O2 Housing and the downpipe on yet. Please let me know if there is something I just don't know about or if it is because of that gasket. Thanks.
Thanks, that helped a lot. It feels pretty much like a smooth transistion now. The Intercooler pipe going to intercooler was loose.
Now I have another question. Ever since the turbo swap, I get idle surge when im in neutral from around 1200 rpm to a little bit over 1600. I tried playing around with the BISS but that didn't do much. Also, at 1000 and 1600 rpm, my AFC was set to -5%. But after the turbo swap, the rpms would bounce lower and lower and sounded like it was going to stall out. I then changed the AFC to 15% and 10% respectively and it kind of took care of that problem, but I don't think it was the smartest thing to do. What do you think?
By the way, there is no o2 sensor on the car right now, I have yet to replace the broken one. I plugged up the hole with a half inch screw right now. Could the idle surge be because of the missing o2 sensor?
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
