oil pump
rip
Oct 29, 2002
Carlisle, Pennsylvania
I'm going to be doing a timing belt soon and i was wondering about the oil pump. The pump it self is behind the oil pan right so why was i told you should change the front cover? Wouldn't i only have to change the actual pump not the cover with the pully on it? thanks guys
so ur saying i should do the case? i just thought the important part was the pump.
:rolleyes: no man... that was the reason I said the case does NOT get wear and tear so no real need to do anything to it cept make sure its sealed good...
ok sorry i just wanted to make sure i understood u right. sorry bout that thanks.
