Puller
- 269
- 19
- Feb 7, 2003
Atlanta,
Georgia
Compression is 155 across the board, car runs fine, but it won't boost past 8 or 9 psi no matter what i set it to, and it's not responsive at all when you give it gas. i hooked the mast directly to the Throttle body, and it still didn't do anything, when i open the oil cap you can feel air coming out...i have a breather filter and the pcv looks nice and clean but it might be bad... was wondering what my problem might be...new 8mm wires and ngk 6's as well, please help
