help, car wont start
fwdtsi
197
Feb 16, 2003
OK, I was spraying a small shot of nitrous the other night and my car suddenly bogged down when I let off the throttle and then it would barely run ( felt like when you take a spark plug off) which lead me to believe I blew my motor. well, after further inspection I found no metal shavings in my oil, I know the head gasket isnt blown, I had no oil spitting out my exhaust and my motor makes no funky noises either. If I take on spark plug off (it doesnt matter which particular one) it will run the exact same... Then my electicals died. I had the alternator tested and they said it was okay, I checked the alternator fuses and they were fine. Now, when I open my door it will sit there and make a repeated click noise over and over. I try to charge the battery and it wont hold a charge. I know this is a whole lot but can somebody lead me in the right direction of what to check? thanks
First off do a compression test because you related it to the nitrus.
Then hook the car up with an ammeter measuring your current draw. Start pulling fuses and disconnecting stuff (like your nitrus stuff for 1) and see what is the big draw on the battery.
Hopefully you didn't mess the motor up.
I should know this but whats a ammeter tester. How much are they? thanks
:laugh: I quoted myself on accident
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
