New Master Cylinder/Still Low Pressure
slowmotiongeniu
43
Mar 17, 2004
rochester, New York
I lost all pressure in my clutch pedal, so I had a new master cylinder installed, and can drive the car again. However, the pedal isn't pushing back with as much force as it used to before I had the problem and had the cylinder replaced.
What could be wrong with this?
What can I do to increase this pressure? Bleed it? Anything else?
P.S. I had the dealer do the work.
Thanks all...
yeah he didnt finish the job. You have to bleed it afterwards. But its not that hard to do yourself.
Don't think he knew enough to do that himself? Needs to be bled multiple times?
Any chance he would have adjusted my engagement point?
dont assume anything just do it your self. Its not a hard thing to do and this way youll know it has been done. Then if still have the problem you can work from there.
