MidNight372
- 40
- Jan 20, 2004
Chicago,
Illinois
Heres the problem: When i turn the car on the battery and coolant
lights stay on. Then when i start to drive (after putting down the
e-brake) the brake light stays on... I thought it was becuz i had
work done to my car and they powerwashed the engine bay. i tried to
reset the ecu bt disconnecting the power to the battery for 15 mins
but it didnt reset the ecu, maybe i didnt wait long enough. so i went to go drive the car and it started to idle low and i mean it droped to like nothing untill i put it back in gear and pushed on the gas... so i brought it back to the house and parked it. I let it sit to see what it would do.. after while the 3 lights would shut off. but as soon as i would give it
gas they would light up.
I think its the battery becuz i would push on the gas just alittle
bit to get it just to about 1g and the lights would brighten alittle
and i had the heat on full and it would push more out until i let
off the gas then the lights dimmed and the heat wouldnt blow as hard.
any suggestions on what i should do or think it is?
