wreckshop56
- 132
- Aug 14, 2003
I HAVE A 97 SPYDER N/T AND THE PROBLEM IS I GOT INTO A FENDER BENDER AND NOW THE CAR IS STUCK IN 1ST GEAR I CANT PULL IT OUT TO NEUTRAL SO THE CAR WONT CRANK THE CLUTCH HAS NO RESTRAINT IT GOES UP AND DOWN EASY SO IM GUESSING ITS THE CLUTCH...THE CLUTCH CUP WHERE U PUT THE FLUID IN HAS A CRACK IN IT SO ALL THE FLUID IS GONE....NE ONE KNOW WHERE I CAN JUST GET THE DAMN CUP THAT HOLDS THE FLUID FROM.... JUNKYARDS TRY TO SELL ME THE WHOLE MASTER CYLINDER THINGY.... ANOTHER QUESTION NE-ONE KNOWS GOOD BODY SHOPS IN THE HOUSTON AREA THAT DONT CHARGE A ARM AND A LEG
THANKS
THANKS
neways if the clutch starts pumping and the shifter still dont come out of 1st gear then what....do i need another trans.. the engine wasnt damaged or nothing the two wires on top of it i checked them and they were both connected
