Ryan james
- 30
- Sep 20, 2012
seaside,
Oregon
I need some info on what is the best place to have my wb sensor? I have heard 18 inches and then I have heard further back is better. Please help on the best.
So I can take out my factory 02 an put my aem uigo right in it's place with no problems?
This is probably the most par on advice here ^All depends on what you want to do.
This is really out there manI'm running the wideband in the factory location. Why? Because its the same sensor VW use as the front o2 and last 150k +
The Jetta that uses the Bosch sensor Used in a LC-1 for exaple. That is their "front o2" as you put it is the pre-cat one as in literally right before the cat. I'd say that is a bit far from any Dsm's front o2 that is about 2" from the turbine wheel
