Problem with TCU Harness no power??
pimpin81
524
Dec 14, 2007
bellingham, Washington
okay so here is the back story, I was running a shift kit while my tcu was out, got a replacement simply plugged the new one in and taped off the wires going to the toggle switches.. then the other day about 4 months later mind you the tcu stops shifting again so without doing any trouble shooting i unplugged the tcu and hooked the switches back up..
now here comes the problem the switches are not working because I'm not getting any power to the entire tcu wiring harness except for 1 wire on the middle of the 3 plugs and just one of thoes get power no other power is dectected on the tcu harness with the car running or off with key on . i get no other power on the entire tcu harness.
All fuses under the dash tested well with a test lght, i did a visual inspection and even took out the ones I couldn't see too well. So can someone help me figure out this little problem because I'm at a loss .... why no power ?
1g 91 eagle talon tsi awd automatic
well i figured it out , further testing of the fuses in the fuse box reveled a blown fuse, i tested both sides of every fuse this time with my test light and descovered that in the middle row under dash drivers side 2nd fuse from the left was blown, once it was replaced i then again had power to the harness..
Tcu however is shot, but my toggle switches are working like a charm again :thumb:
