timing belt jobs near Portland,OR?
lucid15
527
Oct 10, 2008
Portland, Oregon
Anybody know of anyone or anyplace that cand replace my timing belt for cheap? Just got my GSX today and the last time was 60k miles ago. Dont have that much to spend and mechanical experience to attempt it.
even over a local shop which i know the people personally? anything other than water pump and timing belt?
This is not something you want to go cheap on. Take it to a Mitsu dealer even if you have to borrow some money you want to make sure its done right.
Hehe, we must both be equally bored today...
You could contact English Racing and see how much they charge. It isn't rocket science by any means. I've done it at least 5 times on my car and now can do it in less than an hour easy. I would print out the vfaq and go to it, but I have a diy mentality. If somebody is a professional mechanic, they should be able to do a timing belt change... if they are also your friend just print off the vfaq and give it to them and they should be able to do it as good as any Mitsubishi dealership.
another second motion for english racing. Lucas english will do your car right for a good price. I go there all time and would not trust my car with any one else.
I'll 4th that since someone already second that motion,
I REALY hope your not implying anything about me:|(since you don't now me)
I also KNOW that Everyone can trust Lucas and his Crew......That kinda goes without saying....:thumb:
not trying to say anything about your ability to do the job. I was just making a recommendation.:thumb:
If you have not found anyone yet we would be more then happy to do the job. Doubt we will be as cheep as the guy in the garage. We will get the job done in a timely fashion and can handle any issue that could pop up.
How our cost breaks down
$210 labor to do timing belt and BS belt
$ 60 for Timing belt
$ 20 for BS belt
Extras that may or may not be needed.
$60 water pump
$40 Extra labor to install
$85 Hyd tench 50% chance you will need one and not a bad idea to just do anyway
$90 Upto $90 in pulleys about $30ea there is 3 Most of the time they are ok.
$20 coolant and misc small parts
$290-$570 If you truly want to do it so you know you will be good for another 60k doing everything is the way.
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
