B. I. S. S screw is striped
streetenvy
99
Mar 3, 2011
Port Charlotte, Florida
I having idleing issues, it idles fine when i start it up when it seems to warm up it jumps up to 1500-1700 RPM and it doesnt happen all the tme , no check engine light the DSMLINK shows me everything look's fine and other told me to adjust the B. I. S. S srcew, but it's striped so i cant start with that how do i fix the screw so i can go down the list of what can be causing this i just got the car i hate for it to blow up ROFL
Do you still have the FIAV unit on the throttle body. It under the throttle body it makes it run at a higher idle when cool and drops down when the motor warms up you might be having a problem with that. the B.I.S.S is for different elevation to sea level.
