puting on a new intake manifold
dsmgearheadtune
73
Jul 27, 2008
witchita, Kansas
i ended up pickin up a huge ass intake manifold, and im scared right now to put it on because i heard that id have to tkae it to the dealer for the to reprogram the ECU because it would run to rich, is that true?
first off, what turbo do you have that requires a larger intake manifold
secondly, do you have the supporting mods for this setup
third, what dealership do you know that can flash a stock ecu
fourth...time to do some research
ya its non turbo and im planin on keepin it, ive got the cold air, the head done cus i put my gs turbo so i had to make it to were itd handle the pressure, header, and vaccum lines to support any kind overage pressures that couldnt go thru the stock lines, the only problem i have is that im goin to have to re route some of the lines cus on the stock 420 intake theres 3 holes and 1 in the front and also a sensor off to the side (the end of the intake aka passanger side) and theres not a hole for that sensor in the new manifold, but the guy i picked it up from told me that id have to get it reprogramed, it came with a new fuel rail, and injectors, the size of the injectors are unknown. but thanks for pointing that out havoc:D if you guys would like picks of the new intake to put ### i have in words into a picture let me know
Ok, just a couple suggestions.
Mainly, you need to work on your writing skills. I can't understand a word you're saying. First you say its a non turbo, then you say you put your gs turbo. :confused: Clarify that.
And then basically you tell us that you have all this stuff you don't really know about and want to toss it on. My suggestion, don't
to run a bigger intake manifold you definately need to have supporting mods thats a further down the line type part, gotta make sure u can use it efficenetly otherwise its a waste.
