mitsu134
- Apr 2, 2002
does anyone know how to wire a switch to your cooling sensor that if its on it tells your computer that your enigine is cold and shoots more gas into the engine and gives you exta boost?
Originally posted by verserv
You dont want extra gas with out extra air, it causes you to run rich and leaves carbon deposits. I would run 93 octane only and manually advance the timing on an NT if you want that extra "boost". Thats a safer way to do it.
By having the spark plug fire a couple of degrees sooner, you give the mixture more time to burn, thus burning more completely, thus releasing more energy, thus creating more power
Oh sorry i forgot. Timing is 5 TDC, you can advance an nt to about 8 TDC that was where i got confused.
To check the timing or advance it click the link.
http://www.myzero.com/engine/timing.html
