terminaltsi
- 309
- 2
- Dec 16, 2001
louisville,
Kentucky
i've seen a couple kits for spray8ing on the ic and i really like the idea, esp. in the city of hell, phoenix, where it's 88 by 7 am. at that time, the car runs well, but by 1 pm, when it's 110, it runs like crap.... i think a nice cold spray of nitrous or CO2 would help like nothing else. anybody tried this yet? BTW, i have the RRE FMIC.
!!! At least you make me laugh. No, you don't know more than me. You are trying to argue with me for the sake of arguing. I'll coin a popular term for DSM'ers. "show me proof." Prove to me that you know more than me. Apparently you have never used nitrous before, and you are basing your information on hearsay. This is my hole Mary, so why don't you come try to shut my mouth? I really don't like arguing with idiots because you'll simply bring me down to your level, and then beat me with experience.
Now that I'm done playing with that child up there, I'll answer the real question at hand. You have a nice setup, and I would definately wait for the 660's to come in before spraying the car. Start of small, with a 50 shot wet kit. Pull your base timing back to stock if you have ever adjusted it. I would suggest checking the timing anyway before spraying the car to ensure that it's at 5 degrees BTDC. Install new plugs, NGK BRP7ES gapped at .028". Use race gas the first time you spray, just as an anti-detonant because you never know what adjustments you may have to make. The nice part about a nitrous system is they are jetted on the rich side from the factory as a safety precaution. If you need install help, I can help you with that, or you can locate diagrams online as well. Add a set of Web Cam street grinds to that mix, and you will be getting very close to my setup on the Laser. You actually have one up on me because I didn't have a front mount, although I had a very nice balanced/blueprinted bottom end that was .030" over with all stock internals. With getting the nitrous up to around a 75 shot, I don't see why with your setup and cams, you can't make 400 wheel HP on race gas with the 16g. If you decide to do it, good luck, and let me know how I can help.
