2G Zex kit for the second generation turbo?
bradgoodman
Oct 7, 2002
on the zex website it doesnt say it has a kit for the second generation turbo? will it work on a 96 turbo? what would i need to make it work
U need to buy the kit first, then install it. nothing else is needed. jsut "T" into your fuel pressure regulator and your boost controller @ the intake manifold, and bam, you're done. Don't forget to hook into the throttle position sensor. You shouldn't need anything extra from what come with the kit.
you can buy it, but it is an inline type.
you are probably better off at getting
a walboro or something of that type,
the zex kits are designed to work with
bone stock cars nothing needs to be modified
to your car when putting it on but you probably
already know that. What size shot are you putting
through your car? If it is over a 75 shot you need
some kind of fule system upgrade i.e injectors+pump....
U will also need a way to retard your timing. U will notice detonation in 3rd if you do not retard the timing or use race gas when spraying. I have experienced the same thing. And what ever you do, DO NOT spray 75 at any time on pump gas. KNOCK, KNOCK, KNOCK, BOOOOOOOOM!!!!!!
good point about the timing it tells you in the book
how much to retard it. Just about anyone can install a zex kit
they are very userfriendly. It took me about an hour
to install it on my wifes car.. A 75 shot should be safe as long as you have fuel there they wouldnt sell a kit with a 75 shot if the car
couldn't handle it. A buddy of mine has a 75 shot on his basicly
stock gst. It runs fine, he's had it on the car for about a year now...
i got an email from zex that they are coming out with a wet kit, anyone else heard this, i dont want nx cuz i want to stay computerized.
