psychlow
- 2,864
- 15
- Jun 30, 2003
Colorado Springs,
Colorado
Just found this interesting, thought I would share.
One of the problems with traditional water injection on turbocharged engines is that the requirement for the amount of water starts off low and increases as boost increases. On most systems, they're just set to activate a pump or an injection solenoid at x PSI via a Hobbs switch, and pump the same amount of water in regardless of the increase in boost.
The other day, someone on this board mentioned their theory of using a fuel pressure regulator to increase/decrease water line pressure 1:1 in relation to boost. I'd thought about it previously, but dismissed it as I was thinking that water running through an FPR would probably corrode it.
Yesterday, I decided to email Aeromotive about it.
So, it looks like, at least with Aeromotive units, you could set up a water injection setup that would be boost-referenced. Set a Hobbs switch to say, 10PSI, and your base water pressure to 50 or so PSI. So if you're boosting 20PSI, water pressure would be 70PSI, but only 60PSI at 10PSI boost, etc. Then, just tune as needed.
Any thoughts? An optimal setup would use a MAF-metering method, but I'm thinking that this would be the next-best option and a lot less expensive.
Any of the Aeromotive universal bypass regulators, including the low
pressure 13204 and high pressure 13101, 13109 and 13105 are compatible with
alcohol fuels. There would be no issues with respect to the glycol, alcohol
or water in these units. Do NOT however use an Aeromotive in-line fuel pump
to handle water, this would result in immediate fuel pump failure. Good
luck and thanks for choosing Aeromotive!
Brett Clow
Aeromotive Tech Dept
5400 Merriam Dr.
Merriam, KS 66203
PH: 913-647-7300 ext 109
FX: 913-647-7207
-----Original Message-----
Sent: Monday, December 20, 2004 8:50 PM
To: [email protected]
Subject: Using your adjustable FPRs for water injection
Question - would using your adjustable fuel pressure regulators for a water
injection application corrode or otherwise harm the units? I'm planning on
using windshield washer fluid (49.5% distilled water, 49.5% alcohol, 1% blue
dye).
Thank you.
