someone help me please. . .
AlmostStock TSi
36
Aug 19, 2002
W.F., Texas
i have a 92 laser w/ cat-back exh, gutted cat,mitsu metal head gasket, b&m afpr set at about 50psi, and a k&n running at 12 psi, i have been running an NOS wet 50hp shot and was wondering if it would be safe(for the motor) if i were to jet up to a 75 shot ?
Bobby T.
Bobby,
I would suggest before going up with the nitrous, get yourself a ported 95 exhaust manifold and a 3 inch O2 eliminator downpipe. With nitrous, you are creating such a large exhaust pulse, and you need to evacuate that exhaust gas as quickly as possible; if you don't, the end result is high EGT's and potentially burnt exhaust valves, burned up turbo seals, etc. I think you will notice a VERY big gain on the nitrous with the addition of the above two parts alone. Replace the gutted cat with a 3 inch test pipe as well because you don't want any restrictions in exhaust flow. I know jetting up is free, and you have to lay out money to get the manifold and downpipe, but it is well worth it. I would also suggest since you are on the stock turbo, to get a 7 cm^2 turbine housing, and have it ported as well while you are changing the manifold. Every little bit that you can improve exhaust flow on a nitrous car is going to give you big gains. Good luck, and let me know if you need any more advice.
Regards,
thank you very much for your reply and advice. i think i am going to hold off on it for now. thanks again.
Bobby T.
