Reverse Light Problem
shaggy19702
Aug 3, 2003
Quick problem.. My reverse lights don't work.. I've tested the bulbs and tested the fuse and all are fine. I've been told under where the battery is where the reverse switch is for the lights, and I believe i found it. I disconnected and reconnected it and no luck. It was just a standard connector that came out of the tranny. Anyone else had this problem ? Also, on an unrelated note, i took my center console out of my car the other day just out of curiousity. What is the big silver box that rests right under the cup holder ? It has a ton of wires going to it, but i couldn't figure out what it was..
Thanx in advance..
-=<> Shaggy <>=-
99 Eclipse RS
Well for the reverse lights you should make sure the plug is in on the tranny. It is right on top of the tranny like 6 in or a foot from the block. Make sure it looks good and is connected
