no compression on cylender one
nick
154
Feb 13, 2006
Edmonton, AB, Canada
Hi guys, I have no compression in cylender one so I thought that my engine is gone (piston or piston ring). My michanic says that it maybe a bent valve.
what do you guys think. I was hopping it is coz I dont wanna change my engine if posibble. Please help. BTW all 3 other cylender was 150 on compression.
Yeah I did the compression test. All 3 was 150 in I got 0 on cylender 1
Thats the next one I'm going to do. But is it posible that just the bent valve, or I'm looking for a new engine?
you could always do the oil test, where you add a very small amount of oil to the low compression cylinder and see if it raises it when you do another compression test. That could be worn piston rings. If you do the leak down you should be able to pinpoint if a valve is bent and leaking where is coming from either intake or exhaust on cylinder 1.
I put oil when l did the compression but it did not change at all.
Let us know if you end up looking for an engine.. We have great prices right now on all our long and short blocks. let me know if I can help you with anything else, PM me anytime or give us a call (269)350-9055
we are actually building a long block for a guy in Canada now :)
DSM Race Engines
