horizontalkev
Supporting VIP
- 1,000
- 2
- Jun 28, 2010
great bend,
Kansas
For a 99 GSX 6 bolt swap, with rewired walboro 255. Where can I find cheap fuel pump relays? I want to buy a used one from some guys wrecked GS-T but his fuel pump isn't a walboro 255 or rewired like mine is, will the relays be the same?
I jumped the wrong relay pins to try and manually turn on the fuel pump, resulting in a big spark and a non functional relay :/ I was sleep deprived.
Thanks tuners
EDIT -RESOLVED- The relay was found at a Radioshack (aftermarket) I just had to match up a couple of numbers
Thanks tuners
Are the GS-T and GSX relays identical?
funny name
